Problem With Motor Guide Te82v
jww69
:mad:I've got a 01 model motor guide 82lbs. thrust trolling motor, It only works on high by-pass. Checked the voltage at the foot control got 24 volts. Does anyone have any ideas?
jww69
Re: Problem With Motor Guide Te82v
Done some research, and testing, I'm getting voltage to the circuit board. You can hear the relay clicking. Does this mean that it's the circuit board or something in the motor? And also I've read that you can convert from analog, to digital for around 250$, is this true?
