Problem with my motor
Jerry S.
I have a 1988 40Hp Johnson Outboard Electric start,tiller steering. This weekend I had a problem with it dying as soon as I shifted it into forward gear. It ran ok out from the boat ramp. I stopped and put it in neutral when I shifted it back into forward it died immediately. It started right up, shifted and it died again. I backtrolled for awhile then tried it in forward and it ran about 200 yds and quit. Backtrolled again for 10 minutes tried it again and it ran fine. Never had this problem before. Is there a kill switch in there somewhere that was shutting it down. Any ideas?
Yepblaze
Re: Problem with my motor
Look around "in there" and see if there is a wire wrapped up in, or, touching the linkages that is grounding out or being disturbed when you are making this gear change.
