Problem with oil seal installation
hdman97
I am installing all new seals in a 1967 4.5 merc lower unit.
I think whoever was in there before may have installed the seals the wrong way.
For example the one one the top of the water pump was installed with the metal side down,looking at the parts diagram it
looks like it should be metal side up.
How can I tell the proper way for each seal?
Is the rubber lip always toward the oil?
Is there a standard way to install them?
merc850
Re: Problem with oil seal installation
I have looked in my manuals and it seems that the seal for the top of the WP is installed with the lip facing upwards and is installed with Loctite A on the metal edge. I think that it's done that way to stop exhaust from entering the WP.
CharlieB
When in doubt, check the service manual.
Try looking here to see if your manual is still available.
http://forums.iboats.com/showthread.php?t=309079&p=2072211#post2072211
Often times the seal under the water pump is installed with the lip towards the water pump to keep water out of the gearcase.
Propshafts often have two seals one IN to keep oil in, and the outer seal lip out to keep the water out.
Mi duckdown
hdman97 Check the drive shaft at the pump seal. is it rusted or grooved at the pump seal?
hdman97
Yes there was some rust and a groove just at the top of where the seal would be.
