carmangary1
- Joined
- May 11, 2003
- 52
I have a 1972 Johnson 85HP engine. The top of the crankshaft has two lobes on it for opening and closing the points. I am supposed to set my points at .010". The problem is that the lobes are not the same height so if I set the points at .010" on one lobe, when I rotate the crank to the other lobe, the points are at .020". <br /><br />Is this a problem that I can fix myself or should I just live with it. <br /><br />Gary
