roger fernandez
- Joined
- Nov 30, 2004
- 30
I have a problem with my rpms tachometer on my boat and wondering if anyone can advise on what the problem could be.<br /><br />The problem that I been having with it on the last couple of times out, is that its having a much higher rpm reading that the motor is actually doing at that given time, and I say this because it is impossible for me to be doing the king of rpm that is reading at the speed that I'm going, for example, when I have the accelarating lever half way up, normally it would be reading between 3000-3500rpms, now having the lever on the same position it reads past 7000-rpms, also at the moment when its acting up like that, when you touch the gauge/tach its very hot. I check all the connections and there isn't any loose or broken cables also I spoke to a mechanic about it and he asked me if the rectifier was working fine, I checked it and it seems to be working fine, it's charging the batteries properly.<br /><br />Any ideas from anyone on what the problem could be or if its sounds like its actually one of the symptoms that you would get when the tachometer is broken.<br /><br />Any advise on this headache is very much appreciated.
