Jimbrownle
- Joined
- Jun 29, 2009
- 5
I have a 24' Four Winns trailer, and this summer have started having problems with the lights. I've resolved a number of issues, but still have one problem I can't resolve:
If I have the headlights on, none of the lights work. With the headlights off, the brake and turn signals work properly. I have two different tow vehicles, and it problem happens with both, so I don't think it's the tow vehicle.
I tried replacing the ground to the trailer, by drilling a new hole and installing a new ground screw - didn't help.
I put a continuity tester on the wiring without a tow vehicle hooked up. I get a signal when I put the tester on the white (ground) and brown (running lights). I don't get a signal when i test the turn signal/brake lights. I assume this means that somewhere in the wiring the brown and white are crossed.
Short of replacing the whole harness, is there another way to toubleshoot this? Am I thinking about this the right way?
