nemo2011
- Joined
- Feb 15, 2011
- 157
Went to align 4.3 mercruiser alpha 1 and really ran into some snags
We installed motor, torqued rear motor mounts set front down on mounts and fastened in with lag bolts, using the front motor mounts we adjusted so that the alignment tool went in easily, and the spline grease marks were all even on the alignment tool!
When we turned the engine over to 90 deg. the alignment tool would only go in about a1/2" and no more at 180 deg. 270 deg, 360 deg. we could get the spline grease marks to show evenly and the alignment tool would go in and out real easy.
The problems are at 90 deg.
are we being to picky here or what after spending all day doing this and that adjustment we are at a loss why we can not align at 90 deg.
any help here would be much appreciated!
