Darol Wester
- Joined
- Nov 4, 2005
- 157
I've installed new disc brakes on two axles and am trying to bleed the lines. I've bled a lot of cars in my life, but haven't ran into this. Right behind the master cylinder is a Tie Down reverse lockout, then on to the brake lines. For some reason I can't get but just a little if any fluid past the lockout. I've taken it apart, blew air through it and all seems fine. I even hooked it up to the truck in case it was wanting to lock on me. Still no fluid. When the lockout is removed, the fluid is there when pumped. This is all done with the main line disconnected from the back side of lockout that goes to the brakes. Am I missing something here?
