turbojunky
- Joined
- Jul 29, 2008
- 3
any help would be nice. i am posting this for a friend and a little history....
83 70 hp johnson outboard motor
this motor and boat has sat for about 10 yrs till a year ago. Motor ran pretty well untill the oil seal went around the prop. He found a cheap backyard mechanic down the shore so he takes the boat there. he replaced the seal next trip to the water headgasket blown. backyard mechanic put a new headgasket on motor. ever since the boat has never run the same. sometimes it seems to run fine out of the water but as soon as you put the boat in water and in gear will stall or after we already pulled it out of the dock. here we go waving for a tow from passers by. 3 time already!
This so called mechanic he take the boat to all three time said the boat was ready to go. he said he cleaned the carbs replaced the plugs checked the coils put in new fuel filter.
he may have done a few other things but i am not sure. this guy called my buddy and told him that his motor is internally damaged and he needs a new one with no other explaination, except for i have 2 used motors for sale.
well now i am involved with alot of mechanical backround but no outboard motor experience. any advice would help.
my to do list is......
check compession
check spark from coils
try to add fuel to carbs manually with sprat bottle
thanks in advace
check compession
thanks in advace
