After filing through all of the other posted threads, and fixing a lot of little things with the previous topics, I am still stuck with problems on this motor. To start, it is a 1984 Bayliner, with an AQ125A motor and 270 outdrive. The motor came to me with the boat, in pieces. The motor had a lot of machining done to it, and basically just needed assembling. So the things that have been done are, rebuilt block, rebuilt carb, new starter, new plugs, new wires, new alt, both cooling systems rebuilt, most hoses replaced, belts replaced, new exhaust manifold, bellows replaced, and probably some other stuff I am forgetting.
This is my first boat, and has been completely rebuilt, as I have been following a book for this Volvo from page 1. I am extremely new at boats, but I am somewhat familiar now that I have read from front to back, and back to front the manual that I bought to go with it.
The problem I am having is that the book says to time this at 10deg. I replaced the points/condensor with an electronic conversion and cannot get the timing to be any less than 20deg and that is bassically stalling the motor. It runs pretty well at 35 deg, but I am thinking that that is way to early. When I do get it to 'sound good', it will run for about 30seconds to a minute, and then get choppy and die. I have a new fuel pump to replace, but has not been put in yet. I am not sure if that is the problem though. It seems to be getting fuel for a while, and then the thing just dies. I have also installed an inline fuel filter, so I can see the fuel is moving. I also drained the tank, and it has all fresh fuel. I put it on the water after tuning the motor to sound good, and as soon as a load was put on the motor it died, and took a while to get started again.
I apologize for the long post, but I am hoping someone has seen an issue like this before, and can tell me it is something simple. I think I have gone through all of the hard stuff so I am not sure what is left to check. Any and all help would be greatly appreciated, and also thanks to anyone who has posted answers here before, alot of this motor was resurected based on some replies on this board.
Please post your thoughts, and I will try any and everything to get this thing to work.
