Problems with Honda 75
Gmata
I have a Honda 75 HP BF75A
Serial number: BBAL - 3000413
The motor is totally stucked, the crankshaft will not move at all, never had a problem with it, yesteday i took my boat out and started the motor normally, went to the fishing spot (about 30 min) crusing at 5000 rpm and stopped the motor, after a couple of hours i tried to start the motor again and i could just hear a clicking sound when i tried to started, i tought it was the battery and i took the cover off, i got a rope and tried to pull, but nothing would move the wheel above the motor is completly stuck.
The boat had good oil level and like i said never had a problem with it or heard anything weird.
any ideas?
Thanks
dummyman
Re: Problems with Honda 75
Hi,
Would request you to try pulling the starter rope after getting all the four spark plugs removed. If it turns check, starter motor or starter solinoid. Post the reply i shall get back to you.
Regards
any ideas?
Thanks
RonR
Hi,
Regards
Did you ever find out the problum?
