wilkin250r
- Joined
- Feb 9, 2003
- 570
I have a 1988 Force 125 that I've been working on for quite some time. After replacing the entire ignition system, and a complete carb rebuild, I FINALLY got it to start, for the first time since I've had it.<br /><br />However, it will only run at 1/8 throttle, about 1500RPMs. It will not idle. The first and obvious solution would be to check the idle mixture screw on the carbs.<br /><br />I tried that, but I still have the problem, it will NOT idle. What other solutions could there be?<br /><br />Perhaps I still have a dead cylinder? Bad compression? Reeds?<br /><br />I want to do a little homework here and get some possible avenues to check BEFORE I dig into this thing again, rather than post a new question each time I try something.
