I have had this boat about 2 months now.<br /><br />It is a: 1998 Bryant 196<br />Length: 19'6"<br />Weight: Dry 2750 Wet 3500 est.<br />Engine: 1998 Mercruiser 4.3L Carb<br />I/O: 1998 Alfa 1 Gen 2, Gear Ratio 1.62<br /><br />The engine starts and runs good, however Im not getting over 4200 rpm at WOT. I have tried a 14.25x19 and 14.25x21 props. I get the same max RPM with both props. The speed that Im seeing with these props is 19 pitch 39mph and 21 pitch 42mph<br /><br />I have searched this and other boards and the only one that is similar (that I have found) is where they had problems with the anti-knock sensor. Since mine does not have this Im not sure where to go from here. <br /><br />Here is what I have done so far.<br />Took to Marina for tune-up, They did the normal tune-up stuff. <br /> Compression test all cylinders were min of 152psi and max of 155<br /> They set the timing 10Deg BTDC<br /> Changed all oils<br /> Changed oil filter and fuel water separator<br /> Changed plugs<br /> Checked wires, cap and rotor<br />I verified that the tach will go above 4200 I took it to 5000rpm for a very brief instant.<br />I verified that the tach is accurate with in 100rpm at 4500rpm<br />Ran two different pitch props 19 and 21 no change in WOT rpm is 4200<br /><br />I did notice that there is a high rpm stumble above 4000rpm. Will miss several times as you go over 4000 then seems to run fine . However this is running on muffs not under load. A second issue that might be related is it will diesel when you try to shut it off after being run at a moderate to high speed. I have been told that this is a known issue with the 4.3L.
