Procedure for Adjustment
AtlDawg
I have a 73 Chrysler 70 hp and wonder if there is a procedure for shifter adjustment. I have a factory service manual and can't seem to find it in there. <br /><br />Thanks in advance...
WillyBWright
Re: Procedure for Adjustment
If you mean cable adjustment, adjust it so that it grabs forward in about the same amount of lever travel as reverse on your remote control. If you mean the linkage adjustment, then you need the manual. That should be in the factory manual, probably toward the end of the gearcase section.
