procraft steering
basshunter62
Hi guys I have a 15ft. 90 hp merc. 1st boat Ive owned in more then 20 years.last week was my 1st. time out. and the steering felt a little stiff.so before i went out this week I greesed the fitting in the rear piston. now it seems like its stiff in one direction and has a lot of play in the outher direction. is there a correct way to greese this unit. left-right-center I have a merc. manual but it dosent cover the steering unit.
thanx bass hunter
Re: procraft steering
Ayuh,... Odds are, it's corroded inside the tilt-tube...
Disassemble, clean, lube,+ reassemble...
basshunter62
Thanks that was quick. when taking the cable out should the steering be centered, does that matter, ??
Ayuh, it don't matter, other than you'll be turning it every which way to get it to clear everything...
