Its been a while, but got to hear the engine today.<br /><br />Boat didn't make in the water, last season.
<br /><br />Pulled the distributer, and did the drill trick on the oil pump. Replaced the distributer cap and rotor. Found that the prior owner forgot to use loctite on the rotor or a gasket on distibuter cap.
Pulled plugs, and oiled the cylinders, and cranked the engine over. Installed the new NGK BPR6FS plugs. Cleaned the oil reservoir (what is that gunk that settles to the bottom?) and flame arrestor. <br /><br />Took a little cranking, before she fired, and fogged for a minute. Let her warm-up, watching the oil pressure and temps. Motor was running a little rough, but found out the timing was at 10 degrees ATDC. Set base timing to 10BTDC, and she is running smooth. Nice to hear the sound of a V8 again. <br /><br />After measuring a few times, drilled and mounted the smart tabs. Did some other minor cleaning, etc. Lots of cleaning and waxing to go.<br /><br />I only have 2-4-C and Coupler/U joint grease in cartrige. Is one a reasonable substitute for spline grease?
