I have a project motor I am working on a little at a time. Its a 1997 75hp force.I have two problems right now. First the regulator is blown. I have a spare regulator that came from a 1997 40 hp force. The part number is 84515 supposedly it will fit on the 75hp. However the old regulator ON THE 75 was a 4 wire without ground red yellow yellow and gray. I guess the unit is grounded thru the frame. No discernable part number just a date 1996. Probably original part. The regulator from my 40 hp is a five wire yellow yellow red red gray and black ground wire. On the 40hp the extra red wire is hooked to itself basically. Can I do that with this 5 wire regulator, I will have to get a different butt connector to do so 2 into one? When i looked up part number on Iboats it said it would work on a 75hp. Just trying to be careful.
My second problem is the vertical pivot tube that allows the motor to swivel side to side is almost frozen. I belive the motor has to be removed to access this. My problem is engine mount bolts are rusted and Gonna try propane torch to free them. Any advice would be appreciated.
