Project out of control
Robj
I am currently working on a 1992 Excel Bowrider that I bought for a winter project. I am in the process of replacing the stringers and floor. I knew the transom needed some attention, but I did not think that I could pick the wood out with a screwdriver. Anyways it is rotten, at least the bottom half. The boat has a 4 cylinder volvo inboard, and the wood in the transom is about 2 feet wide by 2.5 feet tall. It appears that only the bottom half is rotten. I was thinking replacing it from the inside, cutting half of the skin off, and then replacing only half of it, there are two pieces of ply, so I would stagger the joint. I know that epoxy is the right stuff for the repair, but all the other work that I will be doing is with poly, so I want to avoid expoy if possible. Can I use a thickened poly to bond the new wood to the transom? Any other suggestions?
Thanx
Rob.
tashasdaddy
Re: Project out of control
if you haven't pull the drive and the engine, and replace the complete transom,. or you are wasting your time.
Robj
The drive, engine and transom plate are off. I looked at the transom again and inorder for me to replace the whole thing, it requires me to remove the top half, grind rivets etc, something which I am definetely not going to do. The rot did not go that far, the wood at the top is solid. I will cut it as close as I can to the top, overlap the plywood joints and replace them. I will grind the outside skin with 24 grit, clean it up as best I can, lay a layer of mat, some putty and then the plywood. Cover the ply with mat and wr. I think it will be a good fix. Any other suggestions are always welcome.
Have a great day
Frank Acampora
If the rot is not too bad, try Git-Rot or similar non brand product. I did a section of transom about 3 1/2 feet long and 6 inches deep. The stuff worked just as well as it claimed. Once I mixed it, I thought to myself, "this will never penetrate the wood." But it did--sucked in almost as fast as I could pour it.
Although it is epoxy, it never hardens to a brittle state but stays slightly flexible, so the wood is stronger than original. It is pricey though: 30 bucks for a 2 part quart and that only fixes 105 cubic inches of wood.
Robj
Thanx Frank,
I was planning on using git rot, but it is beyond that, I dug the wood out with a screw driver it was that soft. I think my biggest challenge is to get the poly resin to bond to the transom to make the repair.
Chinewalker
If you're going to attempt to bond wood to wood, then go with epoxy... Epoxy is a glue. Poly is not.
- Scott
