OK so here is the problem. Weak hole shot at full payload! The boat has a good hole shot but add 275lbs and it takes 30 seconds or so to get on plane also the boat doesn't like to stay on plane if let off the throttle at all.
Details
Don't know prop manufacturer but I think it is the original prop that came with the motor. But it is an Aluminum prop.
Prop diameter and pitch unknown as it has no markings anywhere I can see but I do not have a prop wrench so it could be on the back.
Wide open throttle is about 5000. Average speed at full load is 29mph.
Motor is a 1988 Johnson 40hp VRO outboard.
Boat is a 1987 Ozark F141 fisherman modified tri-hull. Length is just over 14'. Weight is 495lbs dry and about 1300lbs fully loaded including motor gear fuel and people.
Any advice?
Details
Any advice?
