Boat Prop
Ok I have a 200hp Etec H.O. 2016 motor on a 2012 Rinker 196 Captiva. Moves fast, gets on plane with 8 people on board easily. The prop that is on the boat is a 14.5 x 19 aluminum.
The WOT Rpm are between what they are supposed to be 4500-5800. If that is correct and I would say it is more in the 5200 if I had to guess but I am not sure.
Regardless I was wondering about a different prop. The boat starts off at a certain speed and slowly climbs to where the throttle gets a bit stiff and then all the sudden it goes from slow to super fast and then I have to slowly pull the throttle back. This can be difficult when skiing or tubing. It just seems there is no middle ground. (is this normal) Because sometimes I pull the throttle back to slow down then it gets off plane.
If I changed my prop to a different pitch or changes from a 3blade to a 4 blade would it make any difference on bottom speed or plane out? I don't care about top speed. This boat is fast but rarely do I go WOT. Can someone give me some advice. I would like to get on plane without having to crank to top speed if that makes sense.
Thanks
Kevin
Thanks
Kevin
