I am in the market for a new prop. I own 2 props now, a stainless that is over pitched for my boat and an aluminum prop that is a little chewed up (chipped tips, etc).
Boat characteristics:
21? Rinker
210 hp mercruiser (alpha 1)
Engine rpm 4200 - 4600
Boat weight (without people) approx 3000 lbs
I tested my two props with the follow results:
14 ?? diameter 21? pitch stainless (Mirage) Prop:
Boat had 4 people ? fuel reached 44 mph and only 3700 rpm
14 ?? diameter 19? pitch aluminum Prop:
Boat had 4 people ? fuel reached 47 mph and 4400 rpm
The aluminum prop characteristics seem to be a good fit for my boat. I could care less about top speed, I am looking for fuel efficiency/cruising (with a load of 6 people) and something that will work for water sports. I would like to buy a used stainless steel prop and my 2 questions are:
-Do I go with a 19? pitch or do I need to adjust for any factors when switching from aluminum to stainless.
-What is the max diameter prop an alpha 1 can handle? I can buy a Mirage prop with 19P but it is 15 1/4? diameter. Will it be too big?
Thanks!
21? Rinker
Thanks!
