1970 Johnson 60 hp hydro-electric
Mint condition 150 in each cylinder
No running or operational problems
(except for the following.....)
Thank you to everyone who can help. I had some oil coming out of the lower unit where the prop shaft seal is pressed in. Removed the hub by removing the 4 allen screws (surprisingly not that difficult considering it could have been stuck to the housing a bit). Replaced the seals, o-rings, etc. that came in the kit. Now the hard part...
The 4 allen screws dont appear to be long enough to reinstall everything, and I know they are the same ones I removed originally. My questions are:
1. How far back should the hub be in the lower housing?
2. Is the front supposed to be flush to the housing rim, or does it set back a bit for the screws to thread properly?
3. This repair appeared so straight forward, am i missing a step with the install?
Thanks again for suggestions. I will check back as often as possible to update and respond to further info asked.
