Re: Prop and sterndrive ratio
Ayuh,......
You're Trying to do what Can't be Done.........
The 3.0l comes With the shortest Gear set there Is,....... 2:1........
There Ain't No Lower.........
Props that Fit your drive are Only available down to a 15" pitch,.....
That Won't get you to where you Think you want to be Either.....
And,........
You're putting More into Loading it than is really There.......
Your engine,+ drive will Like it Much Better,.... If you run Trolling Socks, 5 Gallon Pails, Over extended Trim Tabs, Or Whatever you care to Drag to slow it down........
That'll allow the driveline to Load up,+ stay that way,.....
Trolling with the driveline constantly Loading,+ Unloading is Hard on the engine Coupler,+ Everthing else in the driveline......
In Other Words,....... Your Thinking on getting your Speeds Down,+ RPMs Up,.....
Isn't How it's Done...........
