prop and trim question.
dapup36
I have a 1987-88 skeeter 16ft with a 1980-81 150hp mariner what would be the best pitch prop for all around holeshot and speed. Aprox speed i should reach? Also i need to know what trim unit will fit that motor? thanks
steelespike
Re: prop and trim question.
As far as the prop goes if you check out the stickies at the top of the page and the helps on the prop store page and do some test runs with your present prop we can be much more accurate with a prop suggestion.Best hole shot and speed will be a comprimise.As far as a T&T unit its possible the guys on the Merc/Mariner forum may be able to help.
