Re: prop break in?
Oils on a rubber hub are a no-no. If your mechanic is pressing hubs with oil as a lubricant, get a new mechanic. Or find a new prop shop.
The professional prop shops use a soapy water solution to lubricate the hub as it is pressed in --same as tire mounters lube the rims. According to a major hub manufacturer (HMS Hubs), the soap/water solution will dissipate after about a day and the prop can be used normally when it is delivered.
Because there seems to be some workmanship questions--at least in my mind--You also need to find out if the correct hub was used. Aluminum props, because the prop hub is weaker use a 70 durometer rubber hub to avoid bursting the prop. Stainless use the more firm and durable 80 durometer.
