Johny25
- Joined
- Feb 8, 2012
- 265
Ok I don't know if this is the right area to ask or not but seems as good as any. I mounted my 25hp johnson on my boat tonight and I am not sure if the jack plate is to high? See I had a 9.9 mounted on the jackplate and the 25hp transom bracket lined up exactly with the bolt holes for the 9.9hp that I took off so I didn't want to drill more holes in my transom. Anyway here is a pic of the prop and cavitation plate at the bottom of the boat. Looks like the prop will still be completely in the water and the cavitation plate may be out of the water by a 1/4 inch or less. I won't be able to get the boat out for another week or so and want to fix it now if it looks to high. So if anyone can look at it and say "NO" that won't work or "YES" that should be fine that would be great
I just don't want to get to the lake and find out the prop cavitates and my day is shot. Any info is welcomed.
