Prop change needed for new Setback?
classiccat
I gave myself an early Christmas Present: A Humminbird Sidescan. :cool:
It requires clearance on both sides of the transducer forcing me to give the outboard some setback. I'm installing a 2-piece Jackplate (from T-H Marine) which will give me 4" of setback.
I'm currently using 0 setback and I have the outboard elevated to put the cav plate even with the keel.
2 questions for the experts:
1) Do I need to change the position of the cavitation plate relative to keel with the new setback (if so, approximately how much raise/drop do you recommend...and why?)
2) Is my current prop (10x13) OK to use with the new setback? (If not, what's recommended? 10x15?)
Boat: 16.5' BlueFin Seahawk (1983; converted from a side console to center console; http://www.youtube.com/watch?v=FCUYb5x7IXo)
Outboard: 83' Evinrude 35hp (2 stroke; I est the weight to be 120-130lb)
Prop: 10 x 13
Max Speed: ~25mph WOT (I apologize, I don't have a tach installed for Max RPM with my current setup)
...Or am I completely overcomplicating this considering the size/weight of my engine with this amount of setback?
Re: Prop change needed for new Setback?
Ayuh,... Run it, then see if Anything needs changin'.....
steelespike
Raise the motor to a point just before venting(cavitation) becomes a problem.
