Prop change or not
PELON66
I'm new to boating. Recently purchased a 24 ft pontoon with a 1998 75hp Force 2 stroke. Max rpm 4750- 5250 Definitely needs a new prop. Old prop says 11 5/8 x 11D. Need a correct prop for cruising around no water sports. Just 2 to 4 people max. Any help is appreciated
legalfee
You want to get a prop pitch that will get you close to WOT RPM (accurate tach) with the weight you want to carry. I have a 1995 90 HP Force and use a Mercury Quicksilver 13 pitch aluminum. There are many Prop Selectors out there and some shops will let you try props. I got mine from iBoats. http://boatpropellers.iboats.com/
ahicks
If you aren't towing anything, prop pitch isn't that critical. You don't need to make max power, so a prop that won't spin to full rated rpm isn't an issue. Sounds like an 11p or 12p prop will both work fine. Pontoons don't need anything special, so a cheap prop works as well as a good one. I'd find a Solas prop if it were my boat.
PELON66
PELON66
Makes sense. If and when I do want max power what is the estimated pitch?
ahicks
Whatever will let the engine develop max rpm. If your max is 5000 or so, and that 11p let it turn 4750-5250, that 11 would be pretty close.
