jburn25
- Joined
- Apr 30, 2007
- 104
I randomly was spinning my prop by hand the other day on my 2004 yamaha 90tlrc and notice that it "clicks" when its spun in either direction. I pulled the lower unit off, and attempted to adjust it by hand. When I shift the lower unit into neutral there is a sweet spot that I can hold the shaft in and the prop will spin freely, however, as soon as i release the shifter shaft it moves back to the "un-sweet" spot of neutral and clicks again. Is there someway I can adjust this after I install the lower unit. The shift shaft (the spline thing in the lower unit) just has to be turned just a hair and the prop spins freely.
