Hello, i have a
1987 16 ft bayliner capri with a 85 hp force
i curently have a 17 pitch prop on its banged up needs replacing.
i believe my motor is to run 5200 to 5600 rpm range from reading forum.
i plan to have 3 people max in boat say max 600 pounds but mostly me 200 and 90 lb nephew.
eventually maybe pull a knee board.
the force factory specs calls for 19 inch prop.
prop guy tells me go with a mercury 17 pitch prop it will make the boat plan quicker.
i do not have power trim any advice or insight pros or cons with prop would be appreciated my goal is to make the boat safest to plane and smooth. to drive the boat is for cruising and fishing mostly
thank you for any help.
