I have a older Sea King motor 5 HP built in 1963. The only thing that holds the prop on the shaft is a small 3/16 dia shear pin and a cotter key. A rubber prop cone then slides over the the whole works. If the prop cone comes off the shear pin falls out. Anyone know of a better system for this motor? Or is this as good as it gets. Thanks in advance.
