Re: Prop curious
Dhadley, man the weather ain't lookin' to good is it?<br /><br />Anyhoo, the boat is a '96 Spectre 22', weighs about 1600. The AV plate is probably 1 1/2" to 2" above the keel. I don't know what hole it's mounted in and can't get to the marina to check until next week. I'm guessing I can use about 60 to 70% of the trim range and it ventilates in turns so I have trim down when turning. <br /><br />I've only had the boat for 5 months or so and don't know the history of the prop. I can tell you it's in pretty descent shape visually with a few small nicks here and there.<br /><br />I got the speed from a GPS. The mechanical spedometer reads about 60+ and I know not to trust it.<br /><br />I'm in the middle of a water pump job and plan to change plugs (QL78YC champs), thermostats and do decarb, checking compression before and after. I should have all this completed by the end of next week. Would've been this weekend but work says I gotta be there for the storm.<br /><br />I'll post all results once I'm done. Anything else I should look at?<br /><br />BTW good luck this weekend!
