Prop Damage
drummer0901
I have a 25 P Quicksilver SS prop on an 82 Merc 200. My prop is very slightly nicked on some of the edges. Can I file these nicks out or would this be better done by a prop shop? There are no major nicks or bends mind you.
TIA
Mark
Texasmark
Re: Prop Damage
The name of the game is balance between all of the blades and symmetry to the hub for desired smoothness of operation.
If you have a prop weighing 15 lbs, (as the big ones do) I really doubt that (can't possibly see how) filing little nicks off affects the weight. I have done it many times.
Now if you had a dog eared blade, that could be another story.
But the engine will usually tell you when it's out of balance. It will vibrate and sometimes vibrate the whole boat.
But, from a mechanical standpoint; the lower unit is one tough cookie and an out of balance blade will have to be really bad for a really long time before it would/could wear out your bearings. I think your steering and motor mounts would suffer the most.
HTH
Mark
walleyehed
Re: Prop Damage
Prop damage...huummmm.....
French name for that is Ballistic!!!!:love:
Yes, off-topic, and intended for Marks viewing pleasure....
