imported_John o
- Joined
- Aug 24, 2006
- 137
I am currently running a 15.25x15 aluminum three blade yamaha prop on my yamaha 175hp Vmax hpdi outboard. The boat is a Manitou 24' Osprey Pro pontoon with the SHP package. (three tubes, center one is 25" and set 5" lower then the two 23" outer tubes)
Iboats Boat and Motor Info
1. Year, make and model of boat
2007 Manitou Osprey Pro.
2. Length, width and base weight of boat, look for boat decal on back of boat
24' x 8'6". Weight 4000 (including boat, motor, gas, batteries, incidentals)
2a.What is the recommended HP for your boat
200hp max
3. Number of people and gallons of gas normally on boat
Two people (for these calculations) - about 20 gals gas
4. What do you use the boat for
fishing, cruising, tubing. General purpose do everything boat.
5. Is it a Deep Vee and if so how many degrees of deadrise
Pontoon
6. Year, make and model of motor
2006 (might be a 2007) Yamaha HPDI VMAX 175 Hp.
7. HP and gear ratio of motor IMPORTANT
175 HP - 1.86
7A If you have a mercruiser and don?t know the ratio get your serial off the outdrive and go here http://www.sterndrives.com/mercruisersterndrives.html
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
5500 is normally stated as preferred WOT. Will run up to 6000 with the rev limiter set at 6200.
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches
I believe I am set 1 inch above bottom of center tube
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
no
12. Make, model, diameter, pitch and whether SS or aluminum prop
Yamaha 3 blade 15.25 x 15 aluminum
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. If you do not have a tach you can buy a Tiny Tach for $ 50
5500, upwards of 20 gals (tank is 28 gals when full) 1 person. Speed was 37.6GPS
14. Are you at sea level or a higher elevation, give us the elevation in feet
500feet? (south central Indiana)
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the forgoing could be the reason your prop is not attaining full RPM
Everything seems to be OK. Was last serviced end of last year.
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
Hit a rock with the earlier prop (Michigan wheel 15.25 x 15 three blade aluminum. Roughly same performance). Bought this one as replacement. Got that one fixed for spare. I've used this one for about a year and a half now. Performance pretty constant.
17. Does the prop show any damage that you can see
Nope. Missing some paint on the tips but metal is all good. (It was reworked last year after hitting another rock. The prop shop likes me)
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
With a 15 pitch my theoretical maximum speed is 42mph. So I'm showing about 11% slip. I am wondering if I can drop the diameter and increase the pitch to get more speed.
I'd really like to get over 40MPH.
Question is what will that do to my hole shot (I now hit 15MPH in about 10 sec and 30 MPH in about 20 seconds) and how much do I need for tubing.
Likewise how would it effect cruising (3500RPM) efficiency
I've searched the web and can't seem to find a relation between pitch and diameter. If I go to a 17 pitch my theoretical top speed goes to 47mph which (if slip remains the same) should get me to 42 MPH. But I don't know if dropping the diameter will drop increase the RPM as much as increaseing the pitch will drop them.
Any ideas?
200hp max
Pontoon
175 HP - 1.86
no
Any ideas?
