prop diameter
Sea Hawk
What is the basic standard size diameter of prop for a 225 h.p. merc. on a 2500 pound (dry weight)fiberglass 22 ft. walk-around fishing boat? The pitch is 19. The prop was stolen and I don't remember what the diameter was to order a new one.
Sea Hawk
Re: prop diameter
Also forgot to mention, the prop was aluminum and three bladed. Considering trying stainless this time. Will that change anything? Pitch or diameter?
Spidybot
Re: prop diameter
The diameter is a rather fixed factor. When you order a 19" pitch, there won't be any (or very few) choises.<br /><br />So, if your previous prop worked to your satisfaction go order another 19" for your motor.<br /><br />Stainless may be a good idea but should be considered in relation to the experience you have with the old prop.<br /><br />A good prop show will allow you to test run a couple to help you make the right decision.<br /><br />Do you know what rpm you had at wot with the 19" alu?<br /><br />Check "prop" link bottom of this page.
