Prop diameter
richki
I just bought a new prop for my '86 115 merc. Had a 19 pitch aluminum prop on it. I bought 13 pitch to pull out water skiers but the diameter is 14" and hits the trim tab anode. According to (cringe) Overton's where I bought it, it should fit. Are they wrong, are there different size tabs or am I going to just have to get a different prop? (background- couldn't pull out a water skier on combos with the 19 pitch!)
Dhadley
Re: Prop diameter
Welcome!!<br /><br />Merc has some different options on the tab. Its very common to have to change the tab for props with more rake. No big deal. Overtons should mention that in the catalog. And I'm pretty sure they offer the other tabs too.
Moody Blue
Re: Prop diameter
Hey richki, you have the same post under Merc Troubles. You should not post the same question in multiple areas. Gets too confusing.
richki
Re: Prop diameter
Sorry about the duplicate. Thought I could move this post then delete it but haven't been able to.
Dhadley
Re: Prop diameter
No problem. Have you located the other tab yet?
shep70057
Re: Prop diameter
You could always trim the anode so that the prop doesn't hit it. It's not going to harm anything by trimming it.
