So
For the first time ever, I’ve been not impressed with a laser 2 prop.
Long story short, my new boat came with a 115 efi CT new outboard. Fitted to this when new, was a tempest plus of nearly 15” diameter and 19” pitch.
A bit of a ridiculous prop I assumed for such a boat. It’s a fairly heavy 19ft fletcher cuddy. Deep v but like all fletchers, manage to be quick things.
So with the 19” tempest, it seemed a little heavy for the engine and such a big diameter causes terrible torque steer too at anything other than slow or above my ideal cruising speed.
The engine would manage just over 6000 rpm and 43 mph gps, trimmed up. Incredible for such a set up...but me being used to the campion and it’s cruising rpm of about 2100/2200 rpm (different boat I know), the high cruising rpm of at least 3700 rpm on this boat seemed a little high.
So just to make sure she would be ok with a laser, I put my 19” on to see what happened. As expected the rpm hit the limiter but still managed 41mph. Not bad for a smaller diameter prop.
So. That’s it settled I thought. A good 21” laser 2 with its smaller diameter again will be ideal. Bring the rpm down and also be less harsh into gear and less torque steer. Better on fuel even too.
What a disappointment. It’s better at slow speeds and less harsh into gear...but the cruising rpm is around the same as the 19” tempest at about the same speed too. Then the biggest disappointment...she only managed 38 mph and this was at 5900 rpm. Angry !!
it looks like the tempest is a great prop really. It seems to grip better and allow higher trim and lift. Certainly over the 21” laser at least.
Just goes to show. The world of props. It’s never black and white.
19” enertia to try next...but it looks like a 21” tempest might be the way forward.
