Prop down size
81golfcaddy
Hello I have Carolina skiff venture fs 18 foot fish and ski with a Tohatsu 140.
it takes for ever getting on plane and is about 800 rpm from peak power. It now has a power tech 3 blade 13 inch 20 pitch prop. I'm not looking for top speed so I was thinking about a 4 blade prop for better hole shot and mid-range. My new Nauticas smart tabs came today 80 lb. What would be a good size and pitch on the 4 blade prop for s little more rpm. Thanks hope I didn't talk too much
Leardriver
I doubt that you have a lot of slippage as a problem, so a four blade may not be what you need. You have the get that motor revving up in the power band and make some HP. A 17 pitch 3 blade would be a good start. the problem is that we aren't trying to fine tune, you need a drastic change.
What RPM are you at at full throttle?
achris
More fish than mountain goat
Each inch of pitch is worth about 200rpm. So to gain 800rpm, you'll need to drop 4" of pitch. Go to a 16" picth and see how that goes. If you really want a 4blade (and they are smoother, but you lose a little top end), then use the same pitch.
Chris......
