Re: Prop for 115 yamaha 2 stroke
Prop size usually appears near the base of the blades or under the prop nut.If un marked a prop shop can measure it for you.
A gps can get your speed,something like a Tinytach for your rpm. They have a web site.Reasonable price easy install and can be hand held or permantent.will work on almost any motor with a spark. Rpm is very important for the best performance and the health of your motor. "Very light" I have a 18ft Crestliner utility I would consider "very light" at 375lbs dry weight.I have a feeling your boat is close to twice the weight with the console setup. probably "very light"for a 115.
My brief look at 115 powered boats comepletely un related to your style but all about 1200 to 1600 dry weight similar style.
prop sizes ranged from 23" al prop 5550 @ 49 mph,pro series 19 5500 @ 47,19" @ 46 (1200lb boat) and 21" @ 5450 49.
I think you can see that trying to pick a prop for any boat without real details is nearly impossible.
Sometimes you can luck out with someone with the exact same boat but very rarely.
