Prop for 1984 125hp force
I recently got a 1984 bayliner 2110. It came with a 125hp force and need to replace the prop that is damaged. According to the seller this was the original prop that came with the boat.
This is what I can read on the prop
This is what the engine says.
And found this info.
According to that the model I have is a FPS529 but with a 16 pitch not with a 15 plus is for a smaller size boat. Been searching and don't find much info about the correct prop
Any help is aprecieted as well as where can I get a prop for it.
Thank you.
jimmbo
The 16 may have been discontinued. Don't worry about the charts says, it includes engines ranging from 75hp to 125hp. What rpms are you getting with the current prop? what year is the engine? Is the current prop a thru hub design or does it have a pointy prop nut?
