simplystressed
- Joined
- Mar 16, 2009
- 176
took the 9.8 out for a run the other day on my 1500lb boat.
Looks like I'm getting about 4000-4200rpm at full throttle. The prop says F8.5 so I'm guessing its the stock 8.5D 8Pitch prop on there.
Based on my readings above and weight of the boat, what prop would best suit my setup? I am hoping to gain a slight amount of speed (won't get much over hull at 6mph) and make the most of the motor power/throttle range.
On a small motor like that, does dropping a pitch increase RPM's by 400?
thank you
thank you
