Re: Prop for a 17ft runabout
Well the prop is in bad shape and that is why I'm replacing it. I think it has the stock 13.25x17 3 blade prop on it. I don't know the rpm because I don't have a tach witch I am also in the market for. Any suggestions on a cheap tach that will work on my 1981 90hp vp Evinrude (OMC) would also be nice. The boat is a 17ft Manatee runabout 1974 the boat weighs 1100 and the engine is 300. The weight limit for motor, gear, fule and persons is 1165 witch is probably ushually around 900lb.
