nphilbro
- Joined
- Dec 19, 2011
- 304
Evinrude 200hp ('78) (1.86 Gear Ratio)
20ft Fiberglass Deep-V
14 1/2 x 19 Aluminum
CMC Jackplate 6"x"6 Currenly set with AV plate 1" above bottom of hull
*All speeds on GPS, freshwater
Since I upped my HP from 140 to 200 I'm getting better performance all around, but I think I can do better for cruising on dry-plane which is 22-26mph depending on weight and water conditions with this 200hp. 22 seems to be the low cruise speed with two people 26mph steady control plane. I haven't taken this out on the salt water yet.
First, hole shot is powerful, no complaints, more than I need actually. If I punch the throttle just a bit it responds and will knock you back in your seat.
I've messed with the height of the Jackplate and this is in the rough area of best performance on a small busy lake where I need to make frequent turns.
I'm currently getting 22mph at 3200 rpms which is about 29% slip
I opened it up a bit and got 50mph at 6800 rpms :24% slip
I've got another 700rpms before peak rated 7500 but soon there were two many PWC on the lake and didn't feel like opening it all the way up. Anyway, top end is not what I'm seeking.
I'm wondering if I can move up to a 21 pitch prop and lower my fuel consumption from point to point (5-75 miles) running 3200 rpms. Keeping in mind, I can raise/lower motor (at the dock) and adjust the trim easily on the fly . According to the calculator, at 29% slip I would gain 2mph but I don't know if I higher pitch would lower or raise my slip at cruise speed.
My 140hp was running about 4200rpms on a 13 1/2 x 19 at 22 mph plain so it was burning 6 gallons an hour and running faster than I cared to go for more than 20 minutes at a time. I'd like to cover more distance with the same fuel or decrease time between points with the same consumption.
Any thought? I know going to stainless would help but I would like to get another opinion on pitch before doing that.
I'm also going to wax the hull and get a couple rough spots out this winter.
I'm not worried about it so much on rough water since I actually "drive" through that based on conditions.
