TilleryTom
- Joined
- Mar 1, 2012
- 4
Hey guys,
I need some expert prop advice.
Re-engined with a new Mercury 115 4-stroke engine on my old 1995 Smoker-craft deckboat.
(Old Force 120 seized under power). Marina guy tried the 21p stainless off the Force engine - no good.
3 blade alum 19p very little improvement in either holeshot or top end, and way under rpms. 17p 3 blade alum
much better, but still under 28mph by boat speedo at top end, and very sluggish holeshot. I was thinking of going with a 4 blade Solas Amita alum 15p. Hoping to keep or slightly increase top end, greatly improve holeshot and be able to get on plane and stay there at lower speeds. Open to any suggestions.
: Engine 2011 Mercury 115 4-stroke
: WOT 5800-6400 recommended, actually getting 5800-6000 with the 17p
: At sealevel
: Boat 1995 Smoker-craft Sunship 21ft deckboat. Fiberglass semivee hull. 2000lbs dry wt + engine wt +200lbs gas
+ 200lbs batteries and stuff + 6 people. Approx 4000lbs total. Used mostly for cruising and tubing. Would like to be able to pull up a 200 lb skier. Am I looking in the right direction?
Thanks
TilleryTom
: At sealevel
Thanks
TilleryTom
