Prop for Merc 470
udm328is
Hi there,
I know there is a spot on here somewhere for specific prop info but I can't seem to find it. I have a 19' Wellcraft 192 Classic cuddy cabin. On average I have 2 to 4 average size people along. Sometimes we pull a tube or skier. I am looking to get the smoothest ride first and then best speed. Any and all info is greatly appreciated.
Happy 4th!!
Thanks...
usskydvr
Re: Prop for Merc 470
You're on the correct forum.
ESSENTIAL DATA REQUIRED
When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless and as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
TBTOsterman
I had a merc 470 on my 81 Webbcraft. It was a heavy old boat at about 3000 pounds. I could run a 21 pitch with a light load but for everyday use with passengers and watersports the 19 pitch was the best.
Good luck!
