Prop for my pontoon boat
Mohawkmike
Hi, I have a 2017 Sylvan Mirage 8524 les w/200 mercury verado , tritoon. It has a 15x17 aluminum prop witch is only turning 4200 rpm's . Can anyone help with a correct Stainless steel prop, and pitch?
Sea Rider
Welcome to IBoats,
What's the min-max wot rpm range factory stated for said motor to start with, will know how much prop pitch need to drop for the motor to rev up towards middle or max wot rpm range whichever that range might be. Do you plan boating lightly, medium light or heavily loaded ?
Happy Boating
Faztbullet
Stored in the water,lift or drydock? Boat new to you? Engine been inspected? It should spin that prop easily......
Sea Rider
5800-6400 wot rpm are the tech specs for a in-line 4, 16 valve DOHC motor, if it's the same motor powering your toon at just 4200 wot rpm that motor is being extremely lugged which is no bueno. If the motor is 100% healthy and in top running condition that prop must be changed ASAP for less pitched props, how much less that's the question. Start by querying a Prop Selector...
Happy Boating
