i have a reinell rv 2230 hard top cabin crusier
it weights 3950 lbs
it has a 160 hp mercruiser engine
i took engine and drive from a 18 ' fiberglass boat
so i know prop will be wrong
what size and pitch should i have.
Yes likely it will need a change.Its best to run what you have and get us the prop size and your max rpm and speed at wot.If you don't have a prop I would start with a 17" pitch.A 4 blade would improve hole shot.
