trail-running
- Joined
- Sep 28, 2005
- 3
I recently bought a used boat so I do not know if this is the stock prop on it, ( I doubt it is ).<br />It is a 19 foot bowrider inboard/outboard with a 4.3 L Mercruiser. About 180 H.P.<br />Prop is an aluminum 14.5 x 17. We mainly intend to use the boat to pull skiers and tubes. I have tested the WOT and it is over reving with this prop on it?<br />Engine says 4800 RPM WOT and it is hitting 5300-5400. I know I need to go up to a 19 or 21 prop but will that greatly hurt the performance pulling skiers up? If I went with a Stainless prop at 19 would that bring the RPM down without hurting the hole shot to much? Would a 4 blade prop maintain the hole shot without over reving the engine? Anyone have any suggestions or advice? Thanks.
