Re: Prop for speed ?
Put another way, if your boat were capable of another 20 MPH the manufacturer or the selling dealer would have installed a prop to accomplish that. Make a wide open throttle run with a normal load and note the engine RPM and speed. If the engine is not reaching its recommended WOT RPM it's already overpropped and increasing pitch will likely slow you down rather than speed up. Remember also that a boat has no transmission so increasing pitch to "theoretically" get more speed means you sacrifice hole shot. So if the boat struggles to get on plane now, it will be worse with a higher pitch prop. If you also tow tubes, ski, etc., more pitch will make the boat less versatile. Make sure the engine is performing as it should. You might find that Nauticus Smart-Tabs (trim tabs) will gain speed and enhance boat performance for half the price of a new prop. These forums are full of reports from people that have them and would not be without them. I'm one of them.
