If all goes well, I am going to have a 30 lb thrust 12 VDC Motorguide trolling motor by tomorrow(monday). I know these are generally propped to move bigger boats at trolling speeds.
I am going to be using this trolling motor on a Seahawk II inflatable boat and I want to go as fast as possible using a trolling motor.
The boat is 9' 7" long and with 2 people and battery aboard weighs just under 400 lbs.
My question is, can I use a prop from a higher thrust trolling motor to go faster? Can I use an aluminum trolling motor prop and bend the blades to increase the pitch? Does anybody have any props thye reccomend for speed on a trolling motor? Will a propeller from a small outboard work?
Thanks,
Adam
Thanks,
Adam
